SSTV frequencies (English)
Sub-forum over SSTV
Nieuw berichtdoor Tjalling PE1RQM » 31 mei 2008, 14:39
This list is not complete! You can post more frequencies if you like.
160m
1.916
80m
Can anybody give me the correct frequencies for all IARU regions? This is what I found, but probably not correct:
3.730~3.740 IARU region 1
3.845 and 3.857 Canada
3.845
3.857
40m
7.035~7.045 IARU region 1
7.171 and 7.172 Canada
7.170
7.172
20m
14.227
14.230
14.233
14.236
15m
21.340
10m
28.680
28.690
28.700
6m
50.680
2m
144.500
73! Tjalling, PE1RQM
Plaats ook eens je zelfbouwprojecten op dit forum!
Avatar gebruiker
Geregistreerd: 09 feb 2007, 21:13
Woonplaats: Leusden
Re: SSTV frequencies
Nieuw berichtdoor PD4U » 03 jun 2008, 14:03
Tjalling,
On 40m the calling frequency is 7.033 for IARU region 1 and 3. In Region 2: the Americas 7.171 is used as SSTV QRG. But it seems there is not much activity on neither of the two frequencies.
VK6AAL monitors 40m most frequently with his SSTV cam, and is one of the most active stations on 7033 KHz. See http://users.tpg.com.au/adslsymb/VK6AAL/ for his cam.
73's de Marc, PD4U
http://www.pd4u.nl
PD4U
Geregistreerd: 22 mei 2008, 02:35
Nieuw berichtdoor PD4U » 03 jun 2008, 16:39
PD4U schreef: But it seems there is not much activity on neither of the two frequencies.
ahum... not much activity on either. Or: much activity on neither. So much for logic ;-)
Anyway: almost no SSTV on 40m. Except in VK and JA on 7033 KHz
PD4U
Nieuw berichtdoor pa10403 » 06 jun 2008, 15:49
Tjalling PE1RQM schreef:This list is not complete! You can post more frequencies if you like.
160m...........................
The SSTV frequency on 2 mtr is not 145.500,but 144.500,the 145.500 is a international call frequency on the FM.
Maybe its better to change that.
And in FM mode is the no frequency free on 10 mtr's for SSTV,i guess you can use a simplex frequency for that?
Cheers Gerard PA10403
Avatar gebruiker
Geregistreerd: 02 nov 2007, 14:39
Woonplaats: Eindhoven
Nieuw berichtdoor Tjalling PE1RQM » 06 jun 2008, 16:22
Whoops... I use the 2m frequency quite often, so that was a stupid little mistake.. :) Corrected! Thanks Gerard for warning me.
10m: never used 10m for SSTV yet... sorry....
Avatar gebruiker
Woonplaats: Leusden
Keer terug naar SSTV
Gebruikers op dit forum: Geen geregistreerde gebruikers. en 1 gast
